STF News Posted February 3, 2020 Report Share Posted February 3, 2020 Previously, in order to use custom fonts in existing Xamarin.Forms applications, you had to add the font asset in each platform project and use the FontFamily property to apply the fonts. This was very cumbersome, because each platform required a different syntax for referencing a font file. As we introduced in a previous blog post, using custom fonts in your Tizen .NET applications was not so simple, either. Xamarin.Forms 4.5.0 introduced a new uniform way to specify custom fonts across platforms. You could define custom fonts on each platform and use them in the same way by including them as Application Resources, which was a feature available from Xamarin.Forms 4.5.0 Pre Release 1. We've added Tizen support to this feature, so you don't need to write code to use custom fonts. NOTE: This change is effective as of Xamarin.Forms 4.5.0 Pre Release 2 and higher. This blog explains how to use custom embedded fonts in Xamarin.Forms Tizen applications. Add the font file to your project in Visual Studio To add fonts as resources, perform the following steps in the Visual Studio. 1. Create a folder to store the font files To create a folder for storing the font files, right-click the project folder and select Add > New Folder. Let's call it Resource. 2. Add a font file to your project To add a font file to your project, right-click the Resource folder you just created and go to Add > Existing item..., or drag the file from File Explore (on Windows) or Finder (on Mac) and drop it into Resource folder. You can add TrueType font (.ttf) and OpenType font (.otf) files. To obtain sample font files, go here. Note: Be sure to add the font file with Build Action: Resources. Otherwise, the font file will not be distributed as part of your app. After you add the font file to your project as a Resource, you can begin assigning the font to VisualElement items that have the FontFamily property, such as Label, Entry, and so on. Font name can be specified in XAML or in C# code. As mentioned, you no longer need to know platform-specific rules for specifying FontFamily attributes. Whether it's using the full path and font name separated by a hash (#) as the font name (as in Android) or it's just using the font name (as in iOS), it works well. Note: that the font file name and font name may be different. To discover the font name on Windows, right-click the .ttf file and select Preview. The font name can then be determined from the preview window. Use your custom font in XAML <Label Text="Custom Font 한글" FontFamily ="CuteFont-Regular" /> <Label Text="Custom Font 한글" FontFamily ="Dokdo" /> <Label Text="Custom Font 한글" FontFamily ="PTM55FT#PTMono-Regular" /> <Label Text="Custom Font 한글" FontFamily ="fa-regular-400.ttf#FontAwesome5Free-Regular" /> Use your custom font in C# new Label { Text = "Custom Font 한글", FontFamily = "CuteFont-Regular" }; new Label { Text = "Custom Font 한글", FontFamily = "Dokdo" }; new Label { Text = "Custom Font 한글", FontFamily = "PTM55FT#PTMono-Regular" }; new Label { Text = "Custom Font 한글", FontFamily = "fa-regular-400.ttf#FontAwesome5Free-Regular" }; Screenshot Now that you've reviewed the simple steps in this blog, check out the sample font files, see the many TrueType and OpenType fonts that are out there, and try custom fonts in your own Xamarin.Forms Tizen applications. For any questions or issues you may have, don't hesitate to contact us. View the full blog at its source Quote Link to comment Share on other sites More sharing options...
