Device%20Profile%20Builder%20-%20Samsung
SmartThings continues to invest in the Developer Center with tools for partners such as Test Suite, Product Cloning, and Certification by Similarity to simplify product integration and certification for a single product or an entire portfolio. After obtaining Works with SmartThings (WWST) certification, Analytics helps our partners gain valuable insights about how users interact with their products.
With the goal of making integration easy for partners, SmartThings added another tool in the integration process called the Device Profile Builder, allowing partners to specify a device’s capabilities and how it interacts within the SmartThings ecosystem.
“We’ve heard from developers that they wanted an easier way to build their devices with SmartThings. A tool with an intuitive user-friendly interface that would work for any device,” says Nate Porras, Senior Product Manager at SmartThings. “We feel like we accomplished that with Device Profile Builder.”
SmartThings currently offers Device Profile Builder for Cloud integrations and soon for Direct Connected and Mobile Connected integrations.
“Device Profile Builder is nicely designed and straightforward to use.  You can create a Device Profile effortlessly.  We are always trying to find the simplest way to integrate, and Device Profile Builder is a key tool in that process.”
Anthony Richardson, QA Engineer at August Home
Read on to learn about Device Profile Builder and how to get started.
SmartThings Device Profile Builder is a web-based tool that assists developers with creating Device Profiles, which define a device and its features on the SmartThings platform through Capabilities. It contains the Components—which is a group of SmartThings Capabilities—and metadata (ID, name, ownership, and more) of a device, defining how a device on the SmartThings platform behaves. For example, with a light, the component contains four common Capabilities for lights including Switch, Switch Level, Color Control, and Color Temperature.
Use Device Profile Builder to:
  • Define how you want your products to look to users in the SmartThings app
  • Set SmartThings Capabilities for each of your products
Get Started
How to use the SmartThings Device Profile Builder:
  1. Visit the Products section in the SmartThings Certification Console where you can add a new product or edit an existing one. Under Integration Details / Device Capabilities, click Create a profile here. Or here is the direct link to the Device Profile Builder.
  2. Click the button Add new Device Profile and enter a unique name.
  3. Add your Capabilities and Components. You can also use product category specific templates to make the process faster.
  4. Use the Dashboard View to set how you want your product's icon, action, and state to look in the SmartThings App.
  5. Click Create Profile. After creating, you will have options to View, Publish, Edit, Clone, Download File, Upload file, and Delete under the Actions menu.
  6. Publish your Device Profile and use it to finish creating your product. Then submit your product to obtain the Works with SmartThings (WWST) certification.
You can re-use a device profile for similar products or create as many variations as you need for your portfolio of products.
Device%20Profile%20Builder%20-%20Welcome
Use Device Profile Builder when Creating a Product
Below is the Create Product section in the Certification Console.
In this section, you can provide the product details displayed to users across the SmartThings ecosystem.  Some of these include your product name, product image, and product description to help users identify your product. Plus you can add purchase link URLs so users can buy your product.
When creating a product in the Certification Console, you can use Device Profile Builder to add your device profiles. Under Integration Details / Device Capabilities, click Create a profile here or Edit an existing profile.
After finishing adding a product in the Certification Console, you can test it using Test Suite, and then go on to submit it for Works with SmartThings Certification (WWST).
Create%20a%20Product%20-%20SmartThings%2
Here are images from the Device Profile Builder. We’ll use the Capabilities for your devices as part of the Works with SmartThings certification.
Device%20Profile%20Builder%20-%20Build%2
Devices%20in%20Device%20Profile%20Builde
Templates
Get started faster with Templates. Templates are prebuilt sets of required and suggested Capabilities for common product types that help you create your device profile effortlessly. Simply select a product type and apply it to your component.
Templates%20for%20Device%20Profile%20Bui
Download / Upload File
For even more customization, you can use the Download / Upload File functions to modify the JSON file. If you have a more complex scenario you want to configure, this functionality gives visibility into all the fields. For example, this can be useful for certain devices that have specific preference thresholds or operating limits, which can be configured for normal or alarm states. There is also an ability for more granular control of what your device looks like in the SmartThings app.
Want to integrate your products with SmartThings? Visit our Developer Center to get started and access Device Profile Builder.
      February 2025 Certify your Matter Products with SmartThings – Fast & Easy
      Showcase your Matter products to over 380 million SmartThings users. Getting Works with SmartThings (WWST) certification is easier than ever. Our Developer Center offers many tools to help you certify, including Test Suite. Leverage the Test Suite to easily test your products; many products can even be self-tested without sending them to a lab. Once certified, you can display your products in the SmartThings application and on our website and unlock opportunities for co-marketing.
      Want to learn more? Fill out this form, and we’ll share more details on certifying your Matter products with SmartThings. Samsung Mobile Advance Applications Are Now Open!
      Call for innovators: Applications for our Samsung Mobile Advance Startup Incubation Program are now open. Turn your idea into reality with our 6-month Proof-of-Concept project with Samsung. Visit us for more information.
      Learn More Simple yet Impactful: Emulator Skins for the Galaxy S25 Series are Now Available
      The latest Galaxy emulator skins have been designed specifically for the Galaxy S25 lineup, allowing you to bring the premium look and feel of Samsung’s newest flagship devices to your Android application development. These sleek skins showcase the stunning design, rounded display, and bold style of the Galaxy S25 series. Building applications has never been easier. Download the emulator skins today and start creating applications that truly stand out.
        Download Tutorial: Elevate Your Watch Face with Stunning Weather Forecast Features
      Want to take your smart watch experience to the next level with our dynamic weather forecast features? With Watch Face Studio (WFS), you can seamlessly integrate real-time weather updates, making it easy for users to check hourly and daily conditions at a glance. Smart features like weather tags let you display forecasts while keeping the last update time visible, ensuring users always have access to the latest information. Ready to try it? This blog includes a sample project to help you bring these innovative features to life. Check out the full blog and give your watch face a fresh, weather-smart upgrade!
      Learn More Discover the New Samsung Tizen TV SDK v9.0.0
      The Samsung Tizen TV SDK v9.0.0 is now available! This SDK provides a suite of tools to help you start developing applications for the Tizen TV platform, including an IDE, a lightweight TV simulator for testing web applications, and a TV emulator. Download the new Samsung Tizen TV SDK now from the Samsung Developer Portal and start developing today.
      Learn More Deep Learning for CSI Feedback: One-Sided Model and Joint Multi-Module Learning Perspectives
      In 5G networks, massive MIMO (Multiple Input, Multiple Output) technology is essential for high-speed data transmission and enhanced reliability. To maximize MIMO performance, base stations (BS) require downlink Channel State Information (CSI) feedback from user equipment (UE). However, limited uplink channel resources can lead to overload issues. Therefore, maintaining CSI feedback accuracy while minimizing overhead is a critical challenge.
      To address this, Samsung Research proposes an AI-based One-Sided CSI Feedback method. This approach applies a deep learning model solely at the base station, reducing feedback overhead and protecting data privacy. This solution enables operation without collaboration among vendors. Learn more about the innovative potential of AI-based CSI feedback on the Samsung Research blog.
      Learn More FiRa Consortium Release 3.0 - UWB Core Specification and Certification Program Launch
      Ultra-wideband (UWB) technology is being used in various applications; including localization between smart devices, secure access, and tap-free payment. As recently released at the FiRa Consortium, the wireless communication, energy efficiency, precision measurement, and network connectivity technologies in the UWB Core Specification 3.0, are expected to be more efficiently utilized across various industries, including car access digital keys, public transport services, and path tracking.
      With the Samsung Galaxy S24 Plus models adopted as the Reference Devices for the FiRa 3.0 Certification Program, Samsung Electronics will demonstrate strong interoperability with devices featuring enhanced UWB chipsets. Learn more about the advancements in the UWB technology ecosystem and UWB Core Specification 3.0 certification program, both of which Samsung Electronics are actively involved in.
      Learn More Samsung Instant Plays: Off-Policy Selection for Optimizing Advert Display Timing in Mobile Games
      Samsung Instant Plays is a mobile application that gives users instant access to free games that can be played without installation. The application generates revenue by displaying adverts to users during gameplay. However, displaying adverts too often can lead to user churn, while displaying them too infrequently can result in revenue loss. Therefore, having a strategy for advert delivery timing is crucial.
      To address this, Samsung R&D Institute Poland has adopted an Off-Policy Selection (OPS) method. OPS aims to select the best policy available from a set of policies trained using Offline Reinforcement Learning, remedying the reliability issues in the existing Off-Policy Evaluation (OPE) methods. Find out more about optimizing advert delivery timing using OPS and its results on the Samsung Research blog.
      Learn More
      https://developer.samsung.com
      Copyright© %%xtyear%% SAMSUNG All Rights Reserved.
      This email was sent to %%emailaddr%% by Samsung Electronics Co.,Ltd.
      You are receiving this email because you have subscribed to the Samsung Developer Newsletter through the website.
      Samsung Electronics · 129 Samsung-ro · Yeongtong-gu · Suwon-si, Gyeonggi-do 16677 · South Korea
      Privacy Policy       Unsubscribe
      Earlier this year, SmartThings announced a new program called Certification by Similarity (CbS) within our Works with Samsung SmartThings (WWST) partner program. This program is designed for Smart Home OEM’s to be able to certify portfolios of products, rather than certifying each product one by one.
      Additionally, we released a new developer feature called Product Cloning, which allows partners to input the details of one product and copy for all the similar products.
      Many of our device manufacturing partners have a portfolio of devices that have the same smart technology on the inside but come in many different shapes, colors, and other variations. We are making it easier and more cost efficient than ever to certify the entire portfolio.
      After releasing this new certification option, we have heard excellent reviews from our partners. Read on to discover how to take advantage of this new offering.
      Product Cloning
      SmartThings Product Cloning allows you to enter information for one product and clone it to generate multiple entries for all similar products. The similar products include all the critical information — all you need to do is update the unique identifiers, like the Matter Product ID and Model Number.
      Easily copy product details and enter whole product lines
      Save time and get certified faster
      Get Started
      How to clone a product:
      Visit the SmartThings Certification Console. Navigate to the Products page (second icon from the top on the left). Enter your product details for one product and save it. Navigate back to the Products page. Under the Actions menu on the product, you have an option to create multiple products at once with Product Cloning.
      You can add up to 10 clones with the option to enter the unique identifiers. Once created, the clones appear in your Products list; you can open them up and modify any of the details before submitting for WWST Certification.
      WWST Certification by Similarity
      Certification by Similarity (CbS) allows you to reduce your WWST certification time and cost by identifying related products with similar core functionality but with different model numbers and minor differences like colors, shapes, or regional variations.
      Example Certification by Similarity use case with a portfolio of RGBW, RGB, and white balance light bulbs:
      Start by submitting a primary product for certification that is a superset of all the portfolio features — such as one of the RGBW light bulbs. Once the primary product testing is complete, the similar devices — such as the RGB and white balance light bulbs — can get fast-tracked through certification, for free. Additional devices can be either submitted at the same time as the primary product or at a later date. All you need to do is submit the product information and link it with the primary product. We then verify that the features are the same as your primary product and grant you certification.
      Devices that Can Be Considered for CbS
      The following criteria must be met for the devices to be considered for CbS:
      Note: Cloud Connected Devices may have different Device Profiles and still be considered for Certification by Similarity. This is possible only if the Capabilities for similar products are a subset of the primary product. If a similar device has additional Capabilities, partial testing is required.
      Learn more about CbS in the Developer Documentation and Certification Console.
      Get Started
      How to submit similar products for WWST:
      Visit the SmartThings Certification Console. Navigate to the Certifications page. Submit your primary product for certification. Navigate back to the Certifications page and select the target similar product to certify. You now have the option to link this submission with the primary product. Select the associated primary product and submit your product for certification.
      Certification by Similarity FAQs
      How is the primary product determined?
      → The primary product has all the Capabilities of other devices in the group. In this example, Product 4 or Product 5 could be the primary.
      How can we guarantee CbS will be approved before submitting for WWST certification?
      → We recommend following the guidelines in the Developer Documentation. The WWST team makes the final decision after reviewing your submission.
      Should I submit the primary product and wait for it to be fully certified before submitting secondary devices to be considered for CbS, or can all of the products be submitted together?
      → When submitting products, you do not need to wait. You can submit the primary product and similar products at the same time.
      I have multiple brands, including some that have the same hardware and firmware. Can CbS be extended to these multiple brands?
      → In order to be considered for CbS, products must contain the same brand. View our documentation to review the CbS program requirements.
      How does the publication / timing work for CbS devices compared to the primary product?
      → See our Publish Your Device guide on publication/timing.
      Want to integrate your device(s) with SmartThings? Visit our Developer Center to get started and access Product Cloning and Certification by Similarity tools.
      Engagement Data to Guide Product Development
      What is SmartThings Analytics?
      With our recent update, once you become Works with SmartThings certified, you can use SmartThings Analytics to gather useful data about how your products are being used in the field with PII-safe engagement data. The best part: you can see information like the number of registered and active devices, where your customers are located, and the SmartThings Capabilities that are most commonly used — which helps inform how customers interact with your products.
      Leverage these insights to optimize your products and product roadmap.
      Why Should Developers and Product Teams Use SmartThings Analytics?
      We are always looking for ways to better connect partners with our millions of users.
      We know that it can be difficult to collect user engagement data — especially for partners who manufacture Hub Connected devices.
      Last year, we announced our first version of Analytics, which included Registered and Active devices. After obtaining Works with SmartThings certification, partners can easily access SmartThings Analytics from the Console.
      Since receiving positive feedback on the first version of Analytics, we’ve continued to improve performance and expand the type of data partners can access. New this year, we are providing both country-level data and Capability level use. With Capability data, you can answer questions about the most commonly used features of your product, like “Are users actually changing the color of their lights?”
      Leverage these insights to drive better outcomes for your products and users, and optimize your products based on real user interactions.
      Key Features of SmartThings Analytics
      Real-world Usage Data: SmartThings Analytics makes it easy to know if your users are engaged with your products by providing real-world usage data, which we’ve built in a way that gives you actionable data while still protecting the privacy of users’ data.
      User-friendly Interface: With an intuitive and user-friendly interface, the Analytics tool ensures a seamless experience for product owners and developers of all levels.
      Multiple Ways to Gain Insights: Easily search by an individual product or your entire catalog, within one country or within a region. Or choose to go back as far as 7, 30, 90 days, or with a custom date range. Lastly, see which SmartThings "Capabilities" are being used — there are plenty of ways to get actionable engagement data to drive product decisions.
      Product Questions that SmartThings Analytics Answers
      Where am I getting most of my product sales? In which countries do I have the most active user base? What features / SmartThings Capabilities do my customers use the most? Which are used the least? How many active devices do I have compared to registered devices? How are the active devices and registered devices trending over time? Did device registrations go up after our recent marketing campaign? Or after the event where we showcased our brand?
      How to Get Started with SmartThings Analytics?
      Ready to view Analytics for your device(s)? Here's a quick resource guide to help you get started and show you the features:
      1. Begin by Accessing Analytics
      Analytics is only available to partners who have Works with SmartThings (WWST) certified products.
      Visit the SmartThings Developer Console and navigate to the Analytics section, accessible at SmartThings Developer Console.
      Keep reading for a screen-by-screen walkthrough, or check out this video.
      If you have a WWST certified product(s) , but do not have access to the Console, email us at [email protected].
      2. Set Up Your Search Parameters
      With Analytics you can search by:
      Product(s): Search by one product or all to see a portfolio view of how your products are being used.
      Date: See the last 7, 30, or 90 days of data, or choose a custom data range.
      3. View Data for Insights
      Registered Devices: View devices that are registered with SmartThings.
      Active Devices: View devices with an event or an online status in the last 24 hours. Devices may go from the inactive state to the active state and vice versa.
      Capabilities: See SmartThings Capabilities that are being used for your product or products. Get a glimpse of which capabilities are the most used.
      Geo Location: View by country or region.
      See where your products are being used by country or by region.
      Any of these fields can be made full screen or zoomed in on. The data can be also exported as a CSV.
      Our latest update with Analytics represents another avenue for providing more value for WWST Certified partners. Access to this variety of usage data is critical to understanding how your products are being used.
      Ready to gain more product insights? Navigate to Analytics in the Certification Console to see these insights and apply them to your product strategy.
      Want to integrate your device with SmartThings? Visit https://developer.smartthings.com to access tools like Edge Builder and Test Suite, and then leverage our Certification Console to get your device(s) certified.
