By
STF News
As working from home becomes more commonplace around the world, people are increasingly looking to arrange their workspace so that they can work productively, comfortably and efficiently. But despite our best efforts, sometimes our personal devices don’t offer the capability to review multiple files at once or switch easily between multiple windows as we might require.
This is where Samsung’s high-resolution monitor, the S65UA, comes in. The 34-inch wide screen with 21:9 aspect ratio can help you enjoy a ‘work-from-home’ experience that mirrors the one you have in your office, as you can easily work across web browsers, document files and messenger programs at once – all on one screen.
The spacious desktop screen of the S65UA lets you multitask efficiently and smartly without any extra accessories or clutter on your desk, and its ergonomic stand design lets you customize your setup according to your home working environment. In order to take a closer look at the benefits of the S65UA for those working at home, Samsung Global Newsroom tried out some of its leading features.
Easy Installation and Upcycling-Friendly Packaging
After purchasing new electronic devices such as monitors, we are often left with a plethora of packaging boxes and materials to have to deal with once installation is complete. However, the S65UA comes with upcycling-friendly eco-packaging, meaning you can transform the monitor’s packaging into various practical tools, including objects for your pets and small furniture.
The S65UA’s eco-friendly packaging user manual is also simple to access and easy to use. Simply open up the packaging box, take out the components, and then flatten out the box. With your smartphone, scan the QR code that is printed on the side of the box, and you’ll see a detailed guide to installation. The cardboard packaging box comes with a special dot design that lays out the box’s dimensions in dots rather than centimeters. This means that anyone can create furniture without the need for extra tools to accurately measure the packaging’s lengths.
The next step is to install the monitor itself. The S65UA monitor comes with a stand base, stand neck, power cable, HDMI cable, and USD Type-C cable, so firstly, check you have all the components you need to continue.
The ensuing installation can be roughly divided into two steps. First, put the rectangle-shaped stand base onto the long stand neck and tightly fasten the connecting screw at the bottom of the stand base. When assembling the monitor, all you need to do is just tightly fasten the big screw in the middle. Secondly, simply push the assembled stand base and neck into the back part of the main body, and you’re done. Gently push it upward and you’ll hear a “click” noise, which means you’re all done with the assembly.1
▲ Looking at the dented area on the back of the S65UA monitor, there are 4 additional ports (HDMI, DP, Type-C, LAN).
The S65UA comes with a variety of port types to allow for multifaceted connectivity. Whatever connectivity needs you might have, you can easily connect your monitor to your other devices. In particular, the USB Type-C port can be used to connect portable devices such as smartphones and laptops. With a single cable alone, you can go beyond just connecting the device to the display monitor and enjoy up to 90W charging and fast 10Gbps data transmission for both convenience and versatility.
Customizable Height with an Ergonomic Stand
Productivity can directly be linked to the environment one works in. Even if a device possesses the best performance specs, if it doesn’t match the user’s posture or field of sight, it will become uncomfortable to use after a while. This is why the S65UA comes with a Height Adjustable Stand (HAS), which lets you quickly and easily adjust the height of the monitor by up to 120.00mm (±5.0mm). Simply hold the connecting part of the stand at the back of the monitor and move the monitor up and down to easily and smoothly adjust the height of your screen.
When using the monitor at its highest possible height, you’ll notice that you have extra desk space beneath it to utilize or decorate according to your preference, whether you’re looking for a space to store those extra files or to place some small plants and other flora.
The S65UA also comes with a swivel feature that lets you rotate the monitor to each side by up to 30.0˚(±2.0˚) to further enhance your work productivity. Regardless of which side of the monitor the user is at, the user can rotate their monitor in order to look at the entire screen. This feature also helps you utilize the space you have more effectively. When adjusting the monitor angle, it’s a good idea to gently hold the bezel rather than the display to gently adjust the monitor.
The S65UA monitor opens up more desk space once you’ve oriented it to your desired place, making work productivity and even cooperative work much more convenient. Regardless of how many people are surrounding the monitor, you can quickly and seamlessly peruse the monitor as needed to examine it. Not only does this harness the 178-degree wide viewing angle of the S65UA to its full potential, but it also lets you check the content on-screen instantaneously.
Sitting in front of a monitor for a long time can put unwanted pressure on your body – and a lot of this has to do with our posture in front of screens. If you become used to slouching with your neck leaning forward, the surrounding muscles can become stiff and painful. But thanks to the tilt functionality of the S65UA, you can find the perfect angle to keep you sitting straight and reduce the pressure on your muscles.
Unlike traditional monitors that may have been too tall or too short for optimal viewing experiences, the monitor adjustment capabilities of the S65UA make for a working environment that is more comfortable. What’s more, when taking a break and settling in to watch a movie on-screen for an extended period of time, you can then adjust your monitor some more for the most comfortable viewing experience.
A Wide Screen for All Activities
The S65UA offers a wide screen experience that doesn’t affect your field of sight thanks to its 1,000R display curvature for eye comfort and Ultra-Wide Quad High-Definition (QHD) (3,440 x 1,440) resolution. In addition, the monitor delivers more than 1 billion colors enhanced by HDR10 technology, resulting in true-to-life images and next-level immersion. Whether it’s the dew drops on plant leaves or the small wrinkles on flower petals, the display shows images in vivid, vibrant picture quality, with all colors from light to dark presented without any light blur or clarity obscuration. This creates the best possible viewing conditions for when you need to concentrate on on-screen details, such as when you are playing a game or watching media content.
Those who are accustomed to using dual monitors in the office will find the Easy Setting Box particularly useful. By pressing the control panel button, located on the back of the logo below the middle part of the monitor, you can choose the best aspect ratio from various options whenever you want. Also, Picture By Picture(PBP) shows two input sources on the same screen side by side along with the Picture In Picture (PIP) feature which enables you to open up a small pop-up window within your screen.
Unlike when you have to use multiple monitors to complete a task, there is no need for you to deal with height or color differences across screens, and you can enjoy the near gapless continuity of the monitor’s virtually borderless design for uninterrupted and seamless working experiences.
In order to protect users’ eyes from becoming dry after working for extended periods of time, all monitors from the Samsung 2021 high-resolution lineup come with features that help protect the eyes, leading these monitors to be Intelligent Eye Care certified by TÜV Rheinland, a certification institution of global standards and specifications based in Germany.
New to the 2021 monitor lineup, Adaptive Picture eye care technology automatically adjusts the brightness and color temperature of your screen to one of 42 levels when the environment you are in changes – for example, when your surroundings become darker after working in a bright environment, the monitor adjusts its settings in response to the room conditions. If you’d like to reduce blue light emissions which cause eye strain, you can turn on the special Eye Saver mode by pressing the control panel button. What’s more, Flicker Free technology, which reduces the flickering on the screen to protect your vision, also comes in helpful to maintain your eye health.
In times like this when the home has become blurred with the workplace, the ‘best monitor’ has evolved to become the one that is able to be flexible in response to the user’s environment and delivers the best performance wherever it may be. As well as encouraging you to strike the best balance between work and play while working from home, the S65UA helps increase your work efficiency with ease and comfort.
1 When assembling the monitor, please refer to the user manual that comes with the product.
